Use the following procedure to display information about all MKA profiles configured on the switch. Optionally, you can view information about a specific MKA profile.
  1. To enter User EXEC mode, log on to the switch.
  2. Display all MKA profiles on the switch:
    show macsec mka profile
  3. Optional: Display a specific MKA profile:
    show macsec mka profile WORD<1-16>
The following example displays MACsec MKA profile information:
Switch:1>show macsec mka profile
                               MACsec MKA Profile
Profile    Profile  Cipher    Confidentiality  Replay   Window  Port  Include-SCI
Name        Id      Suite      Offset          Protect  Size
test030519   1     gcm-aes-128   30            Enabled    200    1/3    false
test031519   2     gcm-aes-128   50            Enabled    225    1/4    false
test032019   3     gcm-aes-128   30            Enabled    240    2/2    false
All 3 out of 3 Total Num of MACsec MKA Profiles displayed
The following example displays MACsec MKA information for a specific profile.
Switch:1>show macsec mka profile test030519
                            MACsec MKA Profile
The following table defines parameters for the show macsec mka profile command.
Variable Value
WORD<1-16>
Specifies the MKA profile name. An MKA profile name can consist only of alphanumeric characters (0-9, A-Z, and a-z). The profile name is case sensitive.
